I am looking at these 3 tires from Interco and I am wondering if anyone is or has ran them. I have the ProComp Stage 2 lift kit, and that is why I have only listed the sizes below. I like Option #1, but I am currently running 37" BFG KM2; which do not have the siping like the TrXus M/T. Option #2 looks pretty wild looking. Option #3 is probably the one for winter but A/T's I find in snow seem to ball up. M/T's if sipped correctly throws out the snow.
Thanks for your input
OPTION #1
http://www.tundrasolutions.com/photo...medium/579.jpg
The NEW TrXus Mud Terrain is INTERCO'S answer to the need of those who want a smooth, super quiet ride with tough, thick sidewalls with a chip and cut resistant compound. This tire has more siping than any other mud terrain on the market; which has proven to be almost magical in icy snowy conditions. These same traction features make this tire a serious rock climber.
Each TrXus Mud Terrain tire has its individual specifications and is heavier than the original equipment tires of comparable size. Many brands of tires are made from generic specifications which means there are many "brand names" coming out of a particular factory but all the tires have a common specification basic body or casing. The only difference is the mold the tire is cured in. The tires will have different tread designs but the body of the tire is common to many others of the same size but under various names.
Prod. Code B/RWL: RXM-16R
Weight: 72
Ply Rating: 10
Sidewall Ply: 3
Skid Depth: 21/32
Tread Width: 9.48
O.D.: 35.3
C.S.: 12.4
Rev Per Mile: 617
Rim: 18x10
Max Infla.: 65
Max Load: 3445
OPTION #2
http://www.tundrasolutions.com/photo...medium/580.jpg
The TrXus STS, the STS stands for Three Stage Sidewall, is a new concept in all terrain tires. These tires are not intended to be a substitute for the Super Swamper or Bogger tires but a tire for you if you spend a lot of time on the street. Besides working so well on the street it has good off road performance and excels in snow and sand. It is also very much at home in the rocks and will impress anyone with its all around performance. This tire is going to set a new standard in the all terrain category
Prod. Code: RXS-27
Weight: 71
Ply Rating: 10
Sidewall Ply: 3
Skid Depth: 20/32
Tread Width: 11.46
O.D.: 35.2
C.S.: 12.7
Rev Per Mile: 619
Rim: 18x10
Max Infla.: 65
Max Load: 3445
OPTION #3
http://www.tundrasolutions.com/photo...medium/648.jpg
The VorTrac design combines all of the features that make up a great all terrain tire. It has a tight tread pattern that is well supported toward the base of the pattern for good stability and long tread life. It has a lot of siping to provide traction in wet weather, snow and ice conditions. Some of the features are designed to prevent large stone retention. All of this is brought into a design that is smooth and quite running along with good looks that will enhance the appearance of any vehicle.
Prod. Code: VOR-44R
Weight: 71
Ply Rating: 10
Sidewall Ply: 2
Skid Depth: 16/32
Tread Width: 10
O.D.: 37
C.S.: 13.10
Rev Per Mile: 544
Rim: 18x8.5-11
Max Infla.: 65
Max Load: 3640
