Re: Check out my RCSB
Originally Posted by StangDRA
Thanks for the compliments. The tire size is a 33/12.5/18 There is no rubbing at all on the stock suspension. Tires fit perfect.. Only thing is that it pulls to the right. Wonder why? ?
Is that the TRD off road package? Didn't see any stickers saying it was but thought you may have removed the decals. Did the wider tires effect the ride quality?
If it drove straight before the wheel/tire change, you likely have a tire pulling in one direction. Try switching the fronts to the rear and check it again. If it clears up, you may have a tire that needs replaced.
Performance: Volant CAI; Classic Chambered Dual Exhaust--Powersticks Exterior: Clear lens headlight covers; Westin side steps; Ventvisors-in channel, Spray in liner, Rancho shocks 9000xl front and rear, Silverstar high beams & fog lights, Polarg low beams, TRD oil cap, Chrome door handles, Limited outside mirrors, EGR bug shield, Remote start, TRD rear sway bar, TruXedo Tonneau, Grille overlay, 275/60 on Pro Comp 6066 20x8.5. Interior: Opti Gauges, Limited instrument panel, Weathertech floor mats, Sport Pedals, auto-dim rear view and 35% side window tint.
CBTMA member
 SEARCH FIRST
