Old 07-16-2008, 02:02 PM
mikgrail3 mikgrail3 is offline
mikgrail3's Photo Albums
Last Online: Yesterday 05:03 PM
mikgrail3 is on a distinguished road.
Default Re: 05 Sequoia Hitch Wiring Harness Instructions????
Originally Posted by mysequoia2003 View Post
Here is more info from my previous poated.
Even you don't purchase the towing package, Toyota already pre run the wire to a lower left side under bottom of your truck. There is a black rubber piece covered it. You pull this out then you can see a connector. You don't need to cut or modify anything. There are 2 things require to make this work. 1) purchase the harness wiring from Toyota on the Web, pull the black rubber piece, plug harness in. 2) purchase one factory relay , open a fuse box next to the battery and plug this relay in and you are ready to go. There are 2 harness cables you can purchase from TOYOTA Web. The round one with 7 pins cost around $75. The flat one with 4 pins cost around $40. Relay cost $25. This will save you a lot of money. I did it myself 2 years ago for my 2003 Seq and my friend 2005 TOY recently. I also purchase Drawtide hitch for $125 at a local RV dealer.
Towing wiring harness Part number is 82169-34012
The relays part number is 9098702012
If you can't find these at toyotaparts4u.com, Genuine Toyota OEM Auto Car Parts & Toyota Truck Accessories, just give them a call at 1 877 568 7348. This is a website I purchased all these. You also can find these parts on this website as well. Just select your type of your car and type in the part number. This will give you a price for each item and this is OEM parts. TradeMotion
Good luck!
I did this this weekend on my 04 SR5 2WD. I found the prerun wire and ordered the harness and relay. This weekend I installed the harness and relay (took a whole 5 minutes). But when I plugged it in to a trailer none of the lights worked. When I tested the pins with my meter it was registering that it was working. So I'm a little baffled. I performed the same meter test on my other truck with the same results. I haven't hook my other truck up to the trailer yet though.
Any thoughts?
