Old 07-18-2008, 08:39 PM
WT's Avatar
WT WT is online now
Last Online: Today 05:12 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Talking Lifted with 35" and Pictures to share...
Okay as promised got a few pics real quick this afternoon and got them off the camera. Excuse the dirty truck and all the pics just wanted to give you guys and gals some different angles. I will try and clean it up and take new pictures soon. I also had them pull the stock sensors out of the factory wheels and put them into a DIY air tube I made today and its working great no more light in the dash.
So let me know what you all think of the new look.
I wanted to give some of you here a idea of were its rubbing, so here is a few pics to show were the tires rub. The ties are Nitto Terra Grapplers in a LT325/60R20 D 121R (inflated size of 35.12 X12.91). So they are considered Large 35" tires since most 35" are in the 34" range actually and would probably clear alot of the small rubbing I got with my setup. I corrected the front inner wheel wells with a heat gun a some light pushing to get them pushed back (you could also remove the lower plastic if you wanted) I also corrected one of the body mounts last weekend and will do the other side tomorrow. It involves cutting, welding and grinding if you want to keep that factory look, which I prefer but if you don't mind a un-finsihed look you could just grind or cut the corner off and you be good too. Also the mud flaps were removed as you can see in the pictures.
Front rub ....
Body mount ....
Well hope all this information is helpfull to others here....
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
