Old 07-19-2008, 09:06 AM
MEvang's Avatar
MEvang MEvang is offline
Moderator
Last Online: Yesterday 09:58 AM
MEvang will become famous soon enough.
MEvang's Photo Albums
Default Re: 2003 Tundra 4x4 rotor replacement
You can do this. Brake tubing is a soft composite steel and copper alloy. If not rusty and in good condition it can take bending. But I will causing you, you must support the caliper and the more it is bent them more chance of it cracking. If you want to do this properly I would suggest your first make sure the bleeder will open, then simply remove the line from the back of the caliper or at the hose which ever is easiest to loosen. Plug the line/or hose, do not let the master empty. Once reinstalled flush the front brake circuit with new fluid.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
