Old 07-19-2008, 12:11 PM
MICA4R MICA4R is offline
MICA4R's Photo Albums
Last Online: 07-19-2008 12:11 PM
MICA4R is on a distinguished road.
Default Re: How To Turn Off Vsc For Offroading ? GOOD NEWS
so Here's The Good News! I Found A Glitch... For V6 4wd
Which Means You Can Gas It Around A Corner And Get The Back End To Slide A Little, Or You Can Floor It At A Stoplight And Lay Some Rubber With Rear Wheels Only. Also Means Less Traction So Do This At Your Own Discretion.
*do Not Try This At Home*
I Figured Out How To Get Vsc Trac Control Off During 2 Wheel Drive Mode.
1.) Turn On 4runner
2.) Place 4runner In Neutral
3.) Select H4 (4wd Knob) Wait Several Seconds For 4wd Symbol To Stop Blinking. If It Does Not Stop Blinking Place 4runner In Gear For A Couple Feet (let The 4wd Engage) And Then Back In Neutral.
4.) Press "vsc Off" Button ("slippery Road/car Slipping" Light Will Come On. One Light)
5.) Press And Hold "vsc Off" Button And Hold For About 3-5 Seconds. While Holding Button, Light Will Turn Off And After 3-5 Seconds The First Light Will Come On Along With Another Light That Says "vsc Off".
6.) Turn 4wd Selector Knob To 2wd And There You Have It. You Will Be In 2wd Throw Car In Gear And You're Ready To Lose Traction On Command.
7.) Just A Heads Up This Works Surprisingly Well, And I Was Able To Get A Doughnut On Wet Asphalt With Very Little Difficulty.
8.)feels Just Like My 94 Sr5 4wd In Rear Wheel Mode Only. Feels Good To Get Rid Of Those Damn Computers.
