Old 07-20-2008, 05:47 PM
zephyr01905 zephyr01905 is offline
Last Online: 11-30-2008 12:02 PM
zephyr01905 is on a distinguished road.
zephyr01905's Photo Albums
Default Re: 01 Highlander Stalling
I want to thank everyone for their comments on this site. I also experienced the low RPM/ Stalling issue when not in motion or when coming to a stop. I cleaned the IAC, as talked about here, and the problem is now gone. I used the Haynes manual to determine how get to the IAC, which tells you how to remove the throttle body to get to the IAC - the book listed everything correct with the exception of omitting the fact that you need to remove one throttle body bracket bolt from the rear of the unit. I also took advantage of having the throttle body removed to do a spark plug replacement (this seemed easier than waiting for a later time and having to remove the upper manifold instead). In total, took me, an inexperienced person for repairs, about fours hours total for both jobs - time well spent because the vehicle is purring. Thanks again!
