Old 07-21-2008, 02:35 PM
imjin's Avatar
imjin imjin is offline
ΜΟΛΩΝ ΛΑΒΕ
Last Online: Today 05:31 AM
imjin is a splendid one to behold. imjin is a splendid one to behold. imjin is a splendid one to behold.
Send a message via AIM to imjin imjin's Photo Albums
Default Re: Wiper replacement
I'm not sure if I even had the originals on when I got my truck early on but I'm pretty sure most of them come off the same way. There's some sort of release lever. Worst case, break it loose with a flat head, but take care not to damage the main arm that's attached to the truck, the one with the u-shaped end on it.
