Re: Driveshaft TSB for 4wd
One more question. Please explain how simply adding grease to a joint will keep the drive line from banging. If the problem is caused by improper tolerances how can grease significantly alter the lock-up of something under as much pressure as the drive line on the Tundra? Thank you.
2008 Crew Max 4x4. All stock.
