07-31-2008, 08:52 AM
Re: Towing on 22" wheels
Originally Posted by Only Toyota for me
If the size you gave me is correct ( 285/50/22), then according to Nitto's web site, they are a 10 ply tire which is good. They are rated for 3200lbs per tire which is plenty of tire for you.
The low profile sidewall is definately not the tire of choice for towing. The reason is that you don't have much room between the pavement and the rim. Follow me?
I think you'll probably be fine with them, but they will probably wear out faster than a 65 or 75 series tire. You have a 50 series and they are normally found on sports cars for better handling.
I agree. Those tires will be fine its just that you have a little less sidewall so you'll feel the road a little more and take bumps a little harder but other than that you're fine. 4100lbs is not a huge load anyways.
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, AFE PRO DRY INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
