Old 07-31-2008, 10:29 AM
WAVERUNNERS's Avatar
WAVERUNNERS WAVERUNNERS is offline
Last Online: 10-08-2009 08:03 PM
WAVERUNNERS is on a distinguished road.
WAVERUNNERS's Photo Albums
Default Tow Mirrors Figured Out
Just a little info on tow mirrors. I traded regular mirrors off my sr5 with tow pack. For tow mirrors. They fit nice and plugged right in. trucks with sport mirrors can not be swapped for tow mirrors because you need the 8 wire plug. Easy way to tell is to pull the corner trim off the inside door and look in. also you do not have to pull the door panel off. i did this when I put my on. Pull the corner trim and the little push in button on the front of trim panel closest to the hinges. You’ll have enough room to undo the nut and swap the mirrors. Don’t drop the nut. It took me 10 minutes to do both sides. Good luck.
Last edited by millsp; 07-31-2008 at 11:26 AM. Reason: Please don't type all in CAPS
