Old 08-03-2008, 04:23 PM
07DCwhiteSR5 07DCwhiteSR5 is offline
Last Online: Today 02:00 AM
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
Default Re: TPMS DIY bypass completed and tested with PICS.
my assumption regarding simply unplugging is that its more complicated than that. since they are required on 07 and newer trucks by the govt i can see it setting trouble codes in the BCM and somehow triggering more problems than just a lack of light. including a maint required light or something. i can also see the obd system setting a code not allowing it to pass inspection w/o them working properly. i really like the pipe bomb mod, easy and effective if you are going to run wheels w/o sensors.
