Re: VSC Trac, VSC Off, Brake, ABS lights... all on, all at once.
1203 1231There is a problem with the skid ECU usually the 1203 and 1231 codes are the clincher a fault in the ECU wont let the steering angle sensor calibrate some times there is a tsb for this calibrating procedure but when the ECU is bad they wont clear be sure on the codes most generic scaners cant pull abs codes so spend a little diag $$ at the dealer before you wast money guessing
2002 black sequoia LTD dvd with 6 LCD screens (2 second row and 2 third row rear headrest, center 10" drop down, 5 inch in the pass visor) TRD exhaust K&N intake 03 17" rims Toyota nav system with XM sat radio HID lights
2009 V6SE Camry TRD exhaust HID's 2010 camry LED tailights
