Re: Did anyone run out of gas yet!
If you run this vehicle out of fuel , you will have approximately 3-5 minutes of electrical run time before the ecu shuts the vehicle down completely(HV battery will be depleted). When this occurs the HV battery will then need to be charged with a special battery charger ($35K) that only Toyota has and there are only 5 in the U.S.
I recommend not running this vehicle out of fuel and not to experiment, it could get expensive.
I have had to repair 2 HV camry's that ran out of fuel.
25 yrs with TOYOTA
