Without a "READY LIGHT" The vehicle will not move and the HV system is not really powered up, so it should not drain the main HV battery to much, it will drain the CAR battery because the HV system is not READY and no charging can occur. Drivng in "READY position makes all the HV components ACTIVE and they can drain the HV battery if the engine doesnt run.
I would nt worry to much, just be aware, running out of fuel is bad.....but I know it happens.
25 yrs with TOYOTA
