Re: Did anyone run out of gas yet!
YES, it could burn out a fuel pump, but TOYOTA fuel pumps are rather tough. I personnally have only seen a couple of fuel pumps "die" directly relating to running out of fuel in the last 25 years, on TOYOTAS.
So, yes it is possible, but not likely. IMO. The vehicle will shout down shortly after running out of fuel and you will eventually have to have it towed. By the time you run out of fuel and it shuts down completely and you turn it off, the fuel pump SHOULD still be ok, but it Could die as a result. ......not worth the gamble to me.
Keep the tank over 1/4 and you should never have an issue and it will keep you and the oil companies happy.
25 yrs with TOYOTA
