Old 08-15-2008, 02:20 PM
jgrega jgrega is offline
Last Online: 08-15-2008 04:30 PM
jgrega is on a distinguished road.
jgrega's Photo Albums
Default Re: 23MPG Hydrogen Generator 4.7
The design is very simple and too simple to believe. 3in PVC cut to 9in. 2 caps, 1- 18in piece of 1/2in stainless steel, 2 stainless steel scouring pads, 1qt of water and 1/2 tsp of baking soda, 2 90 degree fittings, 3ft 1/2 hose. The stainless steel is bent into a horseshoe shape that runs down one side, across the bottom, and up the other of the 9in pvc tube. One stainless bolt is drilled through the outside and holds the stainless in place, this is your positive lead. The take the two scouring pads and tie them with stainless safety wire to keep them from hitting the stainless strip and cancelling out the charge. Another bolt is drilled in and connect to the pads this is the negative lead. Pour in 1qt water mixed with 1/2tsp baking soda. Attach cap with a 1/2 in 90 put on it. Connect hose from 90 to intake tube and run your leads accordingly. I have my positive to my ignition so its only on when the truck is on. When power is put to it the h2o is broken down to hho. The h which is lighter than air flows up and out of the tube and into the intake. Simple as that. I can post pics and step instructions later to prove I have this on my truck.
