Old 08-15-2008, 02:55 PM
blacktundra1 blacktundra1 is offline
Last Online: 10-25-2009 03:48 PM
blacktundra1 is on a distinguished road.
blacktundra1's Photo Albums
Default Re: Has anyone had this happen?
You can disconnect your negative cable from the battery then use the test light to hook it (in line)one end to the cable and one end to the negative battery post. Now you can check by open any door you can see the test light will light up then when you close the door it will slowly dim down and off, if the light doesn't go out you have a draw some where.
BT
