Originally Posted by fastman9
I've used Dex III for years with no problems.
That you have used Dexron III for years in a different transmission is fine, but it just might not work in a newer one.
Sort of along the lines of 3,000 mile oil changes and using straight 30 weight oil. Obsolete.
I'll get back to you as soon as I hear from Amsoil about using 'only Toyota' ATF-WA.
My 06 automatic has no dipstick.
Looking forward, on the right rear side is the filler plug. there are two plugs on the bottom of the transmission pan. the larger one, on the right is the overflow. Fill until fluid comes out of the overflow.
