Old 08-18-2008, 04:11 PM
truckin' truckin' is offline
Last Online: 11-03-2009 02:10 AM
truckin' is on a distinguished road.
truckin''s Photo Albums
Default Re: Moto Metal 951, Readylift 2.5", 33" Toyo MT
Originally Posted by jhip View Post
Do you experience any tire rubbing? Will the 2.5" Readylift kit eliminate that?
i haven't really had time to check for any tire rub. as of now, there is no tire rub that i can see, but i have to get a closer inspection to be 100% sure.
Originally Posted by gjose82 View Post
hey "truckin" are you having any problems with your traction control after the lift and rims/tires?
yes, the traction control light flashes when i get on it hard. i'm taking it to toyota to get this fixed in a couple of days. it has something to do with the vsc having to be zeroed in. basically, it means the computer needs to know that the suspension and tire setup has changed. once it's adjusted then it should run like stock. in most cases it will, but there are a few members here that still problems afterwards.
