Originally Posted by MOTORBONES
I need help...
Where did you get the AUX harness?
What color wire was the wire where you jumped the camera from.
The easiest way to get what you need will be to bring the camera wires down from the overhead console there is a spare connector on the left side with all the camera connections. Plus there is a reverse wire save you running to the kick trim.
Remember always check the wires with a meter just in case the colors have been changed on your model as you don't want to send 12VDC into the camera input.
White brings ground to the camera
Black brings supply voltage to the camera
Red is video positive
Grey is video negative
Then on the back of the head unit
Colors and pins as follows
Pin 21 is the camera’s ground.
Pin 24 is supply voltage for camera
Pin 22 is the positive lead for the video signal
Pin 23 is the negative lead for the video signal
I have an AUX harness for sale here or you will need a Canadian dealer but most wont send parts to the US (I called a good few of them)
http://www.tundrasolutions.com/forum...-aux-steering/
Also you will need a connector for the reverse and speed sensors get your self a CD ROM audio cable from a PC and move the pins to the right position it will cost you about $1 the Toyota one with the cable will cost you around $50 again from Canada if you can get it, you can also use the pins from these connectors to fit into the connector on the back of the NAV to connect the camera etc. You just lift the plastic tabs and the pins slip out.
Remember this is a 4 pin not 5 pin so make sure you are connecting to the correct 2 pins on the NAV
