Re: Unichip Tuner
hi, you should need 30 to 50 mile's for the ECU unit to adjust, thats it.
remember you can not switch map A or map B while the truck is running.
you might also dyno the truck. it will give you all the info you want.
rear wheel HP is 310, so anything higher is your gain.
i wish all you gen2 guy's/girl's good luck.
my result's were great. but i have a gen1 2005 4.7 vvti V8.
if i was to guess-
your dyno HP should be around 330 to the rear wheel's.
gorilla
