Re: Unichip Tuner
remember what the directions say's. some times map B isn't the best map to use wether or not you use 93 octane or not.
the only true way to know whats what, is dyno your truck.
i use map A and use 93 octane. and when i need a boost because i have to play, i add a booster to my gas.
also sometime's map B throws a cell code. it has done this for some in the past.
my truck can run both map's without any issue.
i also tried 89 octane once, just to see if there would be a problem. none found. ran great.
gorilla
