Thread: Unichip Tuner
  #386 (permalink)
Old 09-02-2008, 05:14 PM
low c1500's Avatar
low c1500 low c1500 is offline
Last Online: 11-20-2009 11:33 AM
low c1500 is on a distinguished road.
low c1500's Photo Albums
Default Re: Unichip Tuner
Originally Posted by v8hunter View Post
I spent another 800 miles this weekend driving my unichip equipped truck. Here is some more of my feedback below:
Fuel mileage has not increased under normal driving…it is either the same or slightly worse. I have not tried towing anything yet to check that…maybe next weekend.
I am still quite concerned about the lean readings I get on my wideband o2 readings (low 15s and 14s) in 1st and 2nd gear. 3rd gear is marginal with mid to high 13s towards redline. For those of you without a wideband you have probably noticed that the power is pretty weak in those (1st and 2nd) gears with a noticeable jump in power on the shift into 3rd.
I would be satisfied overall if there was not an issue in the first 2 gears as the unichip did seem increase power enough to justify the expense. I do not want to be risking my engine with the first 2 gears being so lean.
I also tried taking off my airraid intake and driving a few hundred miles. Power went down a little, fuel mileage went down a little, and the o2 sensor readings improved very slightly. I am going to put it back on.
Maybe some time spent with my gtech would be well spent. That way we would have more data for others to see. I will be running in 4wd so I don't have to worry about the electronic nannies messing with my results.
Is the lean condition only at WOT??
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
