Re: 2000 echo check engine light
ECU = Engine control unit or the computer that runs everything
Wireharness= all the wiring in between the 02 sensor and the ECU.
If your not so good at electrical, you should get some help from someone who is, and most of the people at AUTO ZONE and places like that are not that good.
25 yrs with TOYOTA
