Old 09-07-2008, 08:21 AM
DCTRDPYRITE DCTRDPYRITE is offline
Last Online: 02-15-2010 10:52 AM
DCTRDPYRITE may have some regrets.
DCTRDPYRITE's Photo Albums
Default Re: Survey Canadain Vehicles MPG readout
Originally Posted by roadstarca View Post
Took a look in the manual (pg 397)and I don't see where it seems to suggest this unless you take English/US to mean British. I believe English/US means US MPG and that is what the accessory meter uses.
If you manually calculate your MPG it is clear that the computer is calculating using US MPG not British.
Maybe there is some way for the dealer to reprogram the accessory meter to change it? If so, it would be nice.
English/US if it only means US MPG would seem a bit of a redundent use of the word ENGLISH unless there is different types of US gallons as in a French or Spanish US gallon for example.
As to the calculation as it presently is the reason I'm asking is because I'm aware that the meter uses US size gallons to calculate MPG.
However Toyota refers to Canadain MPGs when selling the vehicle.
and just as a side note my vehicle is and was bought in Canada I would expect canadain measurement to be used.
What I'm trying to determine is just what you state in you final sentence. Is there a reprogram that can be done and are there any Tundras in Canada with the proper conversion program already in place.
