Originally Posted by sienna_sj
I followed the procedures to reinitialize the power door. It worked. But the power door warning light is still on after the problem is gone. Does anyone know how to reset the power door warning light?
After initialization, cylce the power door(s) open /closed until the light goes out. If you have 1 power slide door cycle it, if you have 2 power slide doors cycle them both. It may take 7-10 times before the light goes out.
If the light still will not turn off then your probably going to need a slide door ecu
25 yrs with TOYOTA
