Thread: Unichip Tuner
  #531 (permalink)
Old 09-12-2008, 09:06 PM
low c1500's Avatar
low c1500 low c1500 is offline
Last Online: 11-20-2009 11:33 AM
low c1500 is on a distinguished road.
low c1500's Photo Albums
Default Re: Unichip Tuner
Originally Posted by Burger Steak & Eggs View Post
This may be all that is wrong here. Relying on canned tunes from small private companies never works because none of them do the R&D needed to make the tune work for all customers (different altitudes, engine wear, temperatures etc). That is not a knock against Unichip, just stating that folks who want to hod rod stuff have to have the means to adjust the air/fuel mix and the rest themselves, or massive grief can result.
I remember back in the '80s when the original 1227747 ECM was first getting broken and people could tweak the code for the first time. Jobber tunes for this camshaft and that stroker kit never worked and always had driveability issues. Only the very basic "stage 1 performance chip" type tunes meant to only add a couple degrees spark advance to an otherwise stock engine actually did something without screwing up the driveability to some degree.
Hey, you worked on the 747's too? Great ECM's , just were slow to sample via laptop.
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
