Re: Rear Window Dead?
30 mintues for me to fix according to the TSB on my 2004, just removed the spring.
It seems that you can probably remove the spring w/o removing the regulator or disconnecting any of the electrical (although, I do suggest removing the negative on the battery...just in case).
If I would have only done that, I think the process would have been 5 minutes.
-=tg=-
