  #75 (permalink)
Old 09-13-2008, 05:26 PM
Mr. Creosote's Avatar
Mr. Creosote Mr. Creosote is online now
Legendary Contributor
Last Online: Today 07:36 PM
Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One. Mr. Creosote is the One.
Mr. Creosote's Photo Albums
Default Re: Post your 1/4 and 1/8 mile times!
Originally Posted by socaliallstar82 View Post
im sure in the 1/4 mile the 2wd would be faster than a 4wd right? 1/8 mile is so short after having ran a 1/4 a month ago, and i could see the benefit of a 4wd. But in general the 2wd is faster because it's lighter right? or am I wrong?
You are correct. Even on a 4x4 switching between 2WD and 4WD you will typically see a slowing of about 2 tenths in 4WD because of the added frictional losses when the transfer case and other guts are switched on. Add to that a true 2WD RCSB will weigh 100-200 lbs less. All of this assumes the 2WD can get traction off the line though.
