Old 09-13-2008, 11:24 PM
truckman261's Avatar
truckman261 truckman261 is offline
Last Online: 02-23-2009 04:04 PM
truckman261 is on a distinguished road.
truckman261's Photo Albums
Default Re: Anyone know how to decode a VIN. ???
Originally Posted by 5keepers View Post
Home TIS Help My Account Logout
Library
Tech Assistance
Vehicle Inquiry
Vehicle Identification Number Search
Enter a 17 Digit VIN below to search for applicable information:
VIN:
Service Campaign
No INFORMATION found for VIN: 5TFMT52177X007461
Vehicle Information
18 Inch Styled Steel Wheels w/P255/70R18 TiresDivision: TOYOTA Model: Tundra Grade: DLX Model Year: 2007
Drive Type: 4WD Body Type: Regular Cab Engine Family: 2UZ Transmission: 5AT
Date of First Use: 12/31/2007 Line Off Date: 06/13/2007 Plant Code: X - SAN ANTONIO PLANT - TMMTX
VIN: 5TF-MT521-77X007461 Standard Equipment: Click here to display
Click here to hide
(Download in progress....)
INTERIOR
40/20/40 4-Way Dr & Pass Adj Cloth
Faced Front Bench Seat, Center 3pt
Seatbelts, Adj Headrests
Dual Zone Climate Control w/Sync Mode
AM/FM/CD w/4 Speakers & Aux Audio Jack
Tilt Steering Wheel
SAFETY
STAR Safety: Pwr Assist 4 Wheel Disc ABS
w/Electronic Brakeforce Distrib (EBD),
Brake Assist, Vehicle Stability Control
with Traction Control (VSC+TRAC)
Dr & Fr Pass Advanced Airbag System
Pass Airbag Cutoff Switch
Dr & Fr Pass Seat Side Airbags
Roll-Sensing Curtain Airbags (RSCA)
Dr & Fr Pass 3pt Seatbelts
w/Pretensioners & Force Limiters
Tire Pressure Monitoring System
MECHANICAL & PERFORMANCE
GVWR = 7000 lbs. Payload = 1780 lbs.
Tow Capacity = 8100 lbs.
271HP/313 Lb-Ft 4.7L DOHC 32V V8 w/VVT-i
5-Spd Automatic Trans w/Sequential Shift
Engine Immobilizer
4WDemand 4x4 System w/Electronically
Controlled 2 Speed Transfer Case
Tow Equip: Hitch Receiver, Supplemental
A/T Cooler, 4.10 Rear Diff w/9.5" Ring
Gear, 130A Alternator, A/T Temp Gauge,
7 Pin Connector, Trailer Brake
Controller Prewire
Automatic Limited Slip Diff (Auto LSD)
TripleTech Frame: Fully-boxed Fr Section
Reinforced C Under Cab, Open C Under Bed
Coil Over Shock Double A-Arm Front Susp
Multi-Leaf Trapezoidal Rear Suspension
w/Staggered Outboard Mounted Shocks
18" Steel Wheels, P255/70R18 Tires
EXTERIOR
8.1' Double-Walled Bed w/Tailgate Assist
Black Bumpers & Grille Surround, Door &
Tailgate Handles, Outside Mirrors
Exterior Color: 0040, SUPER WHITE Interior Color: **13, GRAPHITE
Interior Trim Color: **, * Interior Fabric: *, *
Accessories:
CK : Cold Kit: Heavy Duty Battery, Heavy Duty DZ : AM/FM Audio w/6-Disc Changer, 4 Speakers FE : 50 State Emissions HM : Power Heated Outside Mirrors MG : Front and Rear Mudguards SL : SR5 Package: Chrome Bumpers and Grille ST : 18" Styled Steel Wheels w/P255/70R18 Tires WR : Sliding Rear Window w/Privacy Glass
© 2008 Toyota Motor Sales, Inc.
Did you do that at the dealership or is their a website for it?
Tundra Truck Pro
MODS: Line-X, Sirius, Dual Flowmasters
