Thread: Unichip Tuner
  #548 (permalink)
Old 09-14-2008, 09:13 PM
that1seven that1seven is offline
Last Online: Yesterday 11:28 PM
that1seven is on a distinguished road.
that1seven's Photo Albums
Default Re: Unichip Tuner
Originally Posted by 123456999 View Post
The most obvious reason is because your AFR was at 15.1:1 with the Unichip and around 12:1 stock.
It is generally accepted that the target AFR for maximum torque is around 12.5:1. Of course all engines are different and will need to be fine tuned to find their "sweet spot". But, it's always richer than stoichiometric (14.7:1). The bottom line on your pull was that there was a surplus of oxygen in the cylinder that more fuel could have been burned with.
It'd be helpful to see the AFR that Ryder276 ended up with after his custom tune.
I wish you luck, man. I'd be pissed about a $600 box that needed a $300 custom tune to work right.
yeah 11.6 is wut stock afr was.
i should have time tomorrow during work to give unichip a call, but yes 15.1 is really lean idc if computer suppose to adjust, if computer would adjust it , it wouldn't be 15.1 coming out of exhaust
i'll try to call them tomorrow since, nola said they tried calling me but never had a single call from them.. except once when i left message n they called back.. other than that nothing
