Originally Posted by NOLA_1906
Good runs Ryder. I see you're in California. Can you access 93 octane fuel? Because if you put in 91 octane premium instead of 93, you will get pinging on map B. Unichip tuned map B for 93. Once the knock sensors sense pinging it will retard timing and your power will be below stock. Try some octane booster or xylene at the very least. You're also running on a Mustang dyno which reads lower than others.
No i dont have access to 93. (i'v been using 91)
The tuner took a little timing out so i can use 91
