  #36 (permalink)
Old 09-17-2008, 05:39 PM
Herbicidal's Avatar
Herbicidal Herbicidal is offline
Just a Herbicidal maniac.
Last Online: Today 11:31 AM
Herbicidal's Photo Albums
Default Re: Our new 2008 Yaris 'S' sedan.
Thanks MSR1011! Looking forward to seeing the updated pics of your Tundra.
____________________________
Hey Grumpy in NH, here's what I found on wikihow.com:
Preparing to Drift with a Front Wheel Drive Car
Go to a large, open area.
Pull the handbrake or use the parking brake, riding it out the first time or two to get over your initial fear.
Set up a cone in the middle of the lot.
Drive up to it at speed (between 20 and 30 is desired).
Pull the hand brake and turn toward the cone. Immediately after you feel the back end come around, turn to the opposite direction. This is known as opposite lock.
Repeat the opposite lock at that speed until you can control your car well. Practice this for at least several weeks regularly until it becomes second nature. (Don't do this on roadways. It is dangerous to others and can get you fined.)
Slowly increase speed until you are proficient in a speed you are comfortable with. Get to know that speed--you should never drift above that speed unless you are practicing.
Upgrade. At the same initial speed, flick the steering wheel opposite of the turn and swing it all the way into toward the CONE (not turn, you aren't ready at this stage). As before, when you feel the rear end come around, go to opposite lock.
Drifting with a Front Wheel Drive Car
Approach a turn at a comfortable speed, preferably in mid 2nd gear.
Pull the handbrake while turning into the corner, try not to lock the rear wheels.
You should still have the power on, try not to go less than 1/2 throttle at any time during the drift.
- When you feel the car start to understeer, and lose angle, pul the ebrake harder. - When the car seems to turn too much, give it progressively more throttle, and release the handbrake some. -There is no textbook for drifting. You learn by doing it. -Don't tense up, just feel it.
NOT something I'm going to try! Thanks for the compliment, you may live vicariously through my mods if you like. Heck, feel free to photoshop them onto your own car!
