Re: Prius starting problem! Help!
I have has a couple of prius do this. It turned out to be bad brake light switches. The brake lights worked but there are 2 sets of contacts in the switch. If the ECU does not see your foot on the brake, you will NOT get a READY light.
25 yrs with TOYOTA
