Originally Posted by TiagoHouston
So how about that wiring diagram, also I was thinking since the 08 you have to push 2 times what if you add 2 boxes one for the main switch and the second box for the first box would that work? if that made since Im not good with electrical stuff so idk lol!
Okay did a quick diagram this morning to help you out. As for the 08 needing to do the hold for 5 seconds and hold for 5 seconds again to turn off all there nannies, then yes in theory you should be able to setup a second module to run on a different trigger and timmer after the first one but someone would have to test this out.
