Ok, well I finally got my truck back from the body shop today (getting fixed after an accident). So I got to work on installing the ballasts. I used #8 1 1/2 inch zinc screws with nylon spacers, and nylon screw grommets. Some of the pictures are a bit fuzzy, I need play with my camera settings more and find a way to manually focus.
First I cut the holes for the screw grommets.
Here are the three grommets for the drivers side installed.
What it looks like from behind.
And the drivers side ballast mounted.
The passengers side ballast mounted.
I have still not found out a way to get the high beam indicator to light up when I have both the high and low beams on. But I'll deal with it until a solution is found.
