  #20 (permalink)
Old 09-26-2008, 12:12 PM
WT's Avatar
WT WT is offline
Last Online: Yesterday 10:30 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: VSC bypass mod on my "07"
Originally Posted by stumpm2 View Post
Where can you get the control module from?
Best Prices for the modules that I have found are on ebay (search "pac tr-7"). But you can also sometimes find them at a local stereo/alarm installing shop since these moduels can be used for more than what I used it for depending on how you program them. Soem times these things are called alpine bypass modules too, it just what they orginally were designed to do. I use this same module for a pulse counter in my auto tailgate opener project.
Originally Posted by Dorado77 View Post
Do the indicator lights in the gage cluster come on or stay off?
Yes the dash light do not change function so after you start the truck the light will be on as if you hit the button for the 5 seconds and if you like to turn it off just hit the normal vsc button on the dash and everything goes off again. You can also put a switch inline with say the wiring going to the vsc switch this way it functions normaly unless you have the swicth on then it will automaticly bypass it for you at each start cycle.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
