Old 09-27-2008, 02:55 AM
djosephm's Avatar
djosephm djosephm is offline
Last Online: 01-02-2009 04:32 PM
djosephm is on a distinguished road.
djosephm's Photo Albums
Default Re: For those who have the SOS perf lowering kit
Hey buddy...
I had to cut off my tailpipe and reroute it because
-Before the SOS Racing Lowering kit the springs are above the rear axle.
-Adding the SOS Racing Lowering kit puts the springs under the rear axle and the leaf springs will hit the tailpipe in its normal position.
Solution: If you are going to put this kit on don't worry about your exhaust before you put it on. Go ahead and put the kit on and you will see exactly where you need to cut about 2 ft of tailpipe off with a grinder once you have the kit on so when you lower your jack the exhaust pipe does not hit the springs.
Then in the morning go to an exhaust shop and have them weld some new pipes on for 50 bucks.
Hope this helps.
Dan
2004 Toyota Tundra Stepside TRD Sport Limited Edition
SOS/Tundra Racing Lowering Kit
Alcan Leaf Springs
Tinted Windows
K&N Air Intake
Mobil 1 Synthetic Oil
