Re: Prius Smart Key Fob programing
There is nothing you can do except maybe find another dealer.
They should be able to RESET the SMART KEY ECU, the Toyota scan tool provides this function.
This erases ALL smart key codes, so that they may be re -entered. If the key starts the vehicle that is all it should need. The RESET feature is for just this reason (Immobilizer reset and Smart Key Reset) in case someone looses all their keys (happens alot). You can just reseed the ecu and be on your way again.
If they try this and it does not work they only have 10 tries before the SMART KEY ECU Locks and then nothing will work, then you have to buy the Smart Key ECU for sure.
25 yrs with TOYOTA
