Old 10-16-2008, 10:55 AM
czechm8's Avatar
czechm8 czechm8 is online now
Last Online: Today 04:10 PM
czechm8 is on a distinguished road.
czechm8's Photo Albums
Default Re: 2007 Sequoia radio reception sucks. Has anyone put in an OEM antenna? Signal boos
Your '07 should be just like my '05. There is actually an antenna amplifier in the Toyota Diversity antenna system. There were two antenna plugs on the rear of my stock head unit. A normal sized antenna lead and a smaller one. When I put in all after-market equipment, I used the larger, normal antenna connection for the new head unit. I too had basically no reception, until a seasoned installer pointed out to me the antenna amplifier needs to be powered back up.
For the life of me, I can't remember which wire it was on the harness, but after I restored power to the amp, my reception was fine.
So, if you have an after-market HU, then the antenna amplifier is usually the missing link. Even if you have a stock HU, I would still have the dealer check to see if there is a bad connection related to that amplifier, or if the amp itself is bad. The antennas in the glass work pretty well, so I don't think adding another antenna will solve your problem.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
