Re: Factory cruise control install?
Your going to need the wiring as well. When adding factory cruise to a 2000 Tacoma, there is a list of things needed and what comes in the kit. There is a wire harness listed also.
The instructions are 49 pages long. Pm me your Fax # and I will try to fax it to you.
25 yrs with TOYOTA
