Thanks for the reply. I took a look under the dash and found all the wiring in place as well as the plugs for the ECU and actuator so all I need now is the hardware. I think the only thing that will be a bit of a challange will be the control switch on the steering wheel and even that is plug-n-play.
If I where to put an aftermarket system in I would be looking at more work as there is a separate wire harness and a lengthy proceidure too. Thanks for your help, I'll post my results when...if I get it working
I'm going to get the components next week if I find a truck in the yard with factory cruise. Tim
