  #17 (permalink)
Old 10-19-2008, 06:49 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: door lock actuator 2004
Those 2 rods have a 90 degree end on the, . That end pushes into the clips of the outside door handle and key lock assy. Then the clips get pushed down to where they clip on to those rods. Lift the clips off of the side of the rods and then they should pop out. You may have to usea large screw driver to help pop the door handle rod out after releasing the clip. I think there is a small hole in the door where a screw driver fits to allow you to wendge it between the rod and handle
25 yrs with TOYOTA
