  #36 (permalink)
Old 10-19-2008, 08:18 PM
dibble9012 dibble9012 is offline
Last Online: Yesterday 06:23 PM
dibble9012 will become famous soon enough.
dibble9012's Photo Albums
Default Re: 2005 Tundra DC HID Retrofit Progress
Busy this week so I probably won't be working on it that much. I got both projectors installed, now I just have to tweak the projector alignment. The driver side is a tilted a little, so I need to fix that. I'm glad I could use the stock bulb seal, I did have to trim it a bit though. Just because the size of an H4 connector is a bit smaller than the ignitor connector. I have clear lenses coming in tomorrow. This will give a sharper cutoff and more color in the cutoff.
I also got a chance to really test my harness. Everything works as expected, high beams don't deactivate the ballasts, and the high beam indicator lamp works as it should.
Here you can see the difference between the two cutoffs. The yellow cutoff is a "pre recall" projector.
