Re: Replacement Brake Rotors and Pads - Aftermarket or OEM?
Many people say stick with Toyota brand pads as a replacement and be sure to replace the shim kit and brake grease. The pins may need service, so expect that as a possibility as well. The oem shim kit costs about $35, pins cost about $30, and grease about $5.
I recently replaced my rav4's brakes with Raybestos brand ceramics on all 4 rotors, used oem shim kit and kept original pins. Stops great. In fact, I was on the way down to Raleigh, NC to got to the Vet hospital and at 85mph a deer decides to test my brakes... we're both still alive.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
