Re: Possible Tundra Bed Bounce CURE FOUND
Originally Posted by guntech
I have tried softer springs. Didn't help. Still get the Boing sensation when I hit a road joint.
That overload pak is not the entire spring pak.....
My '70 Bronco has an 11 leaf pak from "Wild Horses". It's a very progressive spring; meaning very soft in its initial travel before firming up.
A pak like that is what would work on the Tundra for those who really don't like the resonance.
the correct spring should NOT lower GVW but it would have more initial squat...air bags would correct that.
'07 Cmax, SR5, 4X4, 5.7......'01 Ford F-250 Crew Cab, V10.....'95 T-100, 2.7L......and about 10 other vehicles that I don't want to bore you with.
