Originally Posted by ASE_Master-Tech
While it is correct that the Hi (max) speed setting will continue to function with a faulty resistor pack, the 'max' setting supply voltage does not run thru the switch.
Most blower motor full speed amperage draws are too high to run directly thru a switch safely & therefor are routed thru a relay, with the switch hi-fan position simply activating the relay.
No offense intended here, just didn't want folks to misunderstand how it works.
You are partly correct here. The supply side of the blower motor is always switched via a relay no matter what the speed setting is. The return or ground side of the blower motor is either switched through a resistor or combination of resistors for the three lowest speeds, but it is switched directly for the highest speed.
