Old 11-13-2008, 05:51 PM
LGL002's Avatar
LGL002 LGL002 is offline
Last Online: Today 12:32 PM
LGL002 will become famous soon enough.
LGL002's Photo Albums
Default Re: Odd whirring noise, occurred overnight, any clues?
Originally Posted by lopezi View Post
I have encountered an odd whirring noise on my '02 Tundra. During the previous day there were no noises or issues and then the next day I go to start it up and there is this odd whirring noise which sounds reminiscent of the noise you hear when you crank the steering wheel all the way to the left or right....but in my case it is there when I first start up the vehicle and doesn't change any when steering to the left or right, nor is the steering affected at all. The sound will go away when the vehicle has warmed up, usually a ride of 10 minutes and the sound has dissipated.
Any ideas/insights into what it might be?
I have replaced the serpentine belt before and I have had the timing belt done. The vehicle currently has 122,000 miles on it.
Thanks,
Ivan
Take a listen down by the heater fan motor below the glove compartment when it's cold. Not unusual for the motor to make some noise when cold with dry bearings.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
