Old 11-14-2008, 07:23 PM
duffyatkinson's Avatar
duffyatkinson duffyatkinson is offline
Last Online: Today 01:43 PM
duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of. duffyatkinson has much to be proud of.
Send a message via Yahoo to duffyatkinson duffyatkinson's Photo Albums
Default Re: O2 Sensor Curiosity Question
I think what happens is that the ECU finds fault on a comparative basis, i.e. the old sensor, while still within parameters, is registering values so far away from the new one that the ECU determines this to be a fault all on its own.
Also note that the O2 sensors on our Tundras are the 4-wire type, wherein 2 wires are used to bring the unit up to operating temperature and the other 2 are the data communications circuit. It's possible that a differential in operating temperature(s) vs. time can throw a code as well.
Don't be surprised to find that you will need to replace all four to keep CEL codes from popping up. And stick with quality Denso or NGK sensors. If you are doing your own R/Rs, hit the base on the front ones and the nuts on the rears with a good blast of WD-40 or PB Blaster beforehand and let it sit for an hour or so to help with removal. Make sure to replace the flange gasket on the rears.
2002 Tundra V8 SR5 2WD AC | Silver Sky Metallic | Chrome Step Bars | Kobalt Low Profile Bed Box
Daystar 2.5" Levelling Lift, 1" Rear Block
Mobil-1 5W-30 | Magnefine ATF Filter 3/8" | K&N AF #33-2144 | NGK Iridium Plugs #BKR6EIX
Russell Speed Bleeders #639560 | Josh's Billet Wing Window Latch Upgrade
11/1/2009: 48,050 miles
* * * I highly recommend http://www.auto-rx.com/ for your engine and transmission! * * *
* * * O2 Sensor Replacement DIY: http://www.tundrasolutions.com/forums/1197269-post2/ * * *
